Bob Hoover HVX mods on wbx?
flyguyeddy
Re: Bob Hoover HVX mods on wbx?
Post by flyguyeddy » Sun Apr 16, 2017 3:54 pm
How would a person shim the hydro lifters for solid operation?
Post by Piledriver » Sun Apr 16, 2017 11:03 pm
With a machined plug to replace the guts, aluminum should work if you can keep the steel cup for the pushrod.
Non-trivial unless you have a handy machine shop.
I'd suggest another set of lifters, and sell the ones you have if still new.
T1 lifters with a groove around the inserts (ID or OD) would work at least as well.
The longer a vehicle rests on jackstands,the more likely it is to remain that way...
Post by Piledriver » Sun Apr 16, 2017 11:12 pm
AMBROSIA wrote:
Mon Apr 04, 2016 5:12 am
Why only one oiling groove?
Will this not restrict the flow similarly to a non modified type 1 lifter?
All the tool steel light weight lifters I have seen are the same design.
The groove is larger than one of the single stock ones but certainly much smaller than a hydro lifter.
I'm thinking it would be easier to modify the bushes by perhaps adding a chamfer to the oiling holes?
I'm still unable to move forward as the lifter/bush combinations I tried so far are all out of spec.
One view is that there is insufficient 'crush' from the existing bores due to wear.
Have them knurled and press them in smothered with green (bushings) locktite.
They won't go anywhere. The knurling increases the effective OD.
You could easily cut oil passage grooves around the bushing ID or OD, taking the lifter out of the feed path.
AMBROSIA
Post by AMBROSIA » Wed Apr 19, 2017 10:36 am
In the end I went with Porsche 912 bushes drilled and honed to match my lifters.
I really like the nice oil groove feature on the od that gives 100% oil flow unlike the normal T1 setup.
Additionally, I enlarged the existing oil holes to match the 7mm gallery bore.
flyguyeddy
Post by flyguyeddy » Tue Jan 15, 2019 12:29 pm
i recently drilled my case for these mods, and it seemed very easy. did the long drillbit hole first then drilled down to meet it. no breakout on the case, thankfully, though i do not know how thin the material is there
andy198712
Post by andy198712 » Sat Mar 16, 2019 10:54 am
its always a risk with that, i did mine (t1) and angled the drill be as much as i could (very little) and only drilled the minimum needed.... defiantly the firs thing to do on a case before spending lots of money on it though ;)
glad yours went well!
flyguyeddy
Post by flyguyeddy » Thu Apr 25, 2019 1:17 pm
Im now wondering if i should spend the money and have that impression welded some, just for safety’s sake.
