Bad Bug Two
panel
Re: Bad Bug Two
Post by panel » Sun Nov 22, 2020 3:23 pm
What brand of wastegate(s) ?
Badbugtwo
Re: Bad Bug Two
Post by Badbugtwo » Sat Nov 28, 2020 10:17 am
Tial, they are both 38mm
Badbugtwo
Re: Bad Bug Two
Post by Badbugtwo » Thu Jan 28, 2021 2:20 pm
More upgrades during the off season! :twisted:
All 4 gears now have the Dave Folts face plates! (Also upgraded to a Weddle 4.13 Ring and Pinion!)
Rev-6 twin disc clutch from Ron Lummus!
CO2 boost control!
...and I realized that I didn't show a pic of a lot of the new engine management stuff...
Ian Godfrey
Re: Bad Bug Two
Post by Ian Godfrey » Thu Jan 28, 2021 9:15 pm
Do those Dave Folts face plates function a bit like a syncro ring?
some very nice kit you have there
Badbugtwo
Re: Bad Bug Two
Post by Badbugtwo » Fri Jan 29, 2021 1:25 pm
Not exactly; they replace what would normally be the synchro ring, cone and hub. This allows full power speed shifting with less risk of failure and longer maintenance intervals. I still use the clutch, but don't lift on the throttle. :mrgreen:
Thank you! 8)
