Hello
I have found Speedaire oil piston driven compressor.
Tank has a hole, but when i opened the air compressor i saw that it still has original honing marks, and electric motor works great.
Can i use soda blasting tank instead of to create hybrid air blaster, because:
i could pick up this locally and make a nice big compressor for less than 150 bucks total
I know that it might be crazy idea, but it can hold up to 125 psi's, or do i need much more
ps i needed this compressor mainly to power sand/soda blaster anyways, so can i mount mechanics at the top or it will not work
sorry im am not spamming please advice looking at the link is it willl be comparable
http://www.harborfreight.com/110-lb-pre ... 95014.html
or am i designated only to this
http://www.harborfreight.com/11-gallon- ... 65595.html
thanx HxC
Air compressor rebuild -need alternative options?
hugging corners
- Dale M.
Re: Air compressor rebuild -need alternative options?
Me, I'd be a little leary of that tank..... I would go for original equipment tank....
Yes its more money but more reliable too..... Ever see a high pressure air explosion.... Its not pretty ...
For about $300-350 you can get a 20 or 30 gallon ASME certified tank with top plate ready to go....
http://www.mcmaster.com/#air-tanks/=bvfy5t
Dale
Dale
hugging corners
Oh perfect
I found 1 for not too bad of a price with mounting plate and wheels+handle
great hint. Thanx
great hint. Thanx
hugging corners
hello
updates, and that's how this compressor evolves
got new tank for 30 plus ring kit for the same
it will be finish painted to match the car with pin striping touches:)
Q:whats the orientation of the 2 compression rings on the piston?
HxC
HxC
