Yes you pop out the rubber flange cap and then you need flat nose snap ring pliers to the snap ring.
For measuring For axle length both the inner and outer CV flange are on the same plane (same height) across from each other. They may straight across or flanges can be either offset depending on length of trailing arm. An example would be using a 3in longer trailing arm, the outer flange would be further back and axle will be at an angle.
This is my Chenowth I bought a few weeks ago. Came without engine or transaxle, but did have the aftermarket 3x3 trailing arms, 930 CVs and axles. And torsion bars eliminators and uses coil overs FOX Shocks for suspension.
The transaxle in pictures is just a dummy setup I am using to see how much clearance I have around.
Need help with Chenowth rear IRS
- jsturtlebuggy
Re: Need help with Chenowth rear IRS
Joseph
- jsturtlebuggy
regnad,
Since it has been only me with answering you, posting on other site can give you more feedback to help you.
A couple of other sites that have off road sections are, The Samba.com and Racedezert that you may want to look at.
Joseph
One thing about staying here is that I have never seen some of the things shown done before so the info would be good here too.jsturtlebuggy wrote: ↑Tue Nov 23, 2021 7:58 am regnad,
What kind of terrain are you using the rail for and how much travel do you expect to get. The spring plates seem to be short but then...
Thanks all for the help. Got 930 cv's with 19.25 axles on their way.
- jsturtlebuggy
Good to hear that you have it figured out and have the parts coming to get it back up and running.
Joseph
FYI, never purchase from https://ljaircooledengines.com/
Crooked AF, made 4 discrete orders and paid for 3 day priority on all 4 orders and they put in one box and shipped ground. Lost time, lost money and these clowns won't even respond to my emails. Literally stole from me.
- jsturtlebuggy
Never heard of them before you posted link. Sorry to hear you had bad deal with a parts suppler.
For off road parts I buy from KarTek in Corona, Fibercraft in Reno, Pacific Customs in Corona, McKenzie’s in Anaheim, and Moore Parts in Anaheim.
I always had good luck with buying parts from these places. Both KarTek and McKenzie’s are both involved with off road racing and have very knowledgeable people to talk to. You may pay a little more, but them sharing their knowledge is priceless.
Joseph
