https://forums.aussieveedubbers.com/vie ... 861&page=9
This a 9 page post and therory about fiting a rack on a trailing arm front end, As I said I removed my narrowed baem and had a major improvement in handling and ride.
Making my 72' standard handle....
- ChadH
Re: Making my 72' standard handle....
Check out this episode of Project Binky. No, It's not a beetle, but the concept should be the same. Move the suspension through it's whole arc, sans springs, and measure how much the steering angle changes throughout. Adjust tie rod heights and angles to minimize the changes.andy198712 wrote: ↑Wed Jul 25, 2018 3:41 am..Is there a check for bump steer without driving it? I can mount it at what ever angle I want I think so can get this right now..
How much this helps - I dunno? but Project Binky is cool!
https://www.youtube.com/watch?v=ob-FUF0Sh_E
I’ll have a play once the body is back on, just looking forward to actually driving it again now!
if it helps my 4inch beam isnt actually 4inches narrowed.... i cut my leaves down two inches either side them dimpled, all exact as if it was 4inch narrowed....
when i come to fit the arms the leaves are too short!
So next set of leaves, then measured how far the dimples were out from a stock beams edge, then copied with on my new beam and hopefully this should be a perfect fit.
absolute text book "trust no one and measure twice" example here folks lol
its more like a 3inch narrowed beam!
- ps2375
Try the GAZ shocks, they are adjustable and very reasonably priced. For every day diving I have my fronts set at "0" and the rears at "7", out of 20 detents. For auto-x I had very good results with the FR at 8 and RR at 10. I drove it home with those settings and it was VERY stiff, i can't imagine going stiffer on them.
I know it's an old thread but I had my rear GAZ adjustables set to 10 clicks, drove nice.
Fitted the front, set to 10 clicks, about ripped my spine out of my nostrils.
Dropped the front to 3 clicks.
Handles a dream now.
Similar dilemma Andy.
I'm on 165/60 up front on a 4.5j rim, would like to band them out to 5.5/6" to get a 195 on but then would need to narrow it couple inches.
Potentially better keeping the 4.5j with stock width and HD arb?
That's interesting.
Would be nice if that works out! I'll see if I can get some measurements.
- chickensoup
you are referring to these right? https://gazcoilovers.com/vw-beetle-1200 ... 1364-p.asp
they look nice. and they seem to work for you guys. would you say they are better, the same, or worse than konis?
Those shocks are for K&L. They won't fit your 72.
