Back up light switch
kg2457
Post by kg2457 » Wed Dec 11, 2019 7:48 pm
How in creation do you get into and reach for the back up
Light switch on an AT 4 speed from my kg?
Thanks,
Bruce2
Re: Back up light switch
Post by Bruce2 » Fri Dec 13, 2019 4:56 am
What are you trying to do?
kg2457
Post by kg2457 » Fri Dec 13, 2019 6:52 pm
Rearranging the wiring in the engine compartment
And want to be able to reach the two electrical contacts.
Is there a trick here?
Bruce2
Post by Bruce2 » Sat Dec 14, 2019 4:47 pm
You should be able to re&re the connectors using your needle nose pliers.
