I have a Megasquirt Jimstim $50
Nissan SR20DET CAS machined to VW distributor specs with DIY autotune wheel, would supply a crank trigger signal for EFI. $75
009 distributor modified to provide crank trigger signal. $75
Misc. DB37 and DB9 cables and ends. $15 for all
TD05 Turbo from Chrysler, very minimal shaft play with 2 exhaust housings, exhaust flanges and gaskets. $75
All prices plus shipping, will make package deals.
Thanks Kenric
Misc EFI/turbo parts
- woodsbuggy1
- woodsbuggy1
Re: Misc EFI/turbo parts
I have pics of everything, just not loading correctly, please PM me for more info or pics.
Kenric
Kenric
- woodsbuggy1
Pics
Does the 009 also have a nissian cas in it? The individual sensor will distributor need modified?
- woodsbuggy1
The 009 has a custom built sensor built into the cap, the Nissan setup has been machined to fit a VW. If you would PM me your cell # I would be happy to send you more pics.
Thanks Kenric
Thanks Kenric
