misfire
misfire
Hello, I am having intermittent misfire from #1 cylinder at Idle, I changed the plug and it corrects the problem for a minute and then the issue becomes progressively worse. I have checked it with a timing light and it is intermittent. I have swapped coils, wires and plugs and it only does it on #1 cylinder. in my data log I can see that the dwell increases when the engine speed slows down, does anyone have any opinion on this, I am at a complete loss. i know enough about refi to get into trouble and thats about it, it is a 2276 and I'm running ms3- EVO wasted spark at the moment. Thanks for the help
- sideshow
Re: misfire
Go back to the basics, what does the plug look/smell like? What is the leak down or compression compared to the other holes?
- grelland
Re: misfire
Have you checked valve adjustments?
- Chip Birks
Re: misfire
What kind of coil? Smart or dumb?
Re: misfire
I haven’t checked the valves, it’s really odd because I had the issue a while back and then I tore the engine down and out new bearings in it and it’s doing the same thing. So I’m thinking it’s an electronic problem not mechanical but I could be wrong. They are gm ls coils. I’m waiting on a part for my cam sync so I’m currently running wasted spark until the part comes in
- grelland
Re: misfire
I was messing around a lot last summer also, with misfires and popping. I checked all eletronics and fuel issues, but it turned out to be the valves in the endvolksdragn wrote: ↑Mon Dec 17, 2018 6:39 am I haven’t checked the valves, it’s really odd because I had the issue a while back and then I tore the engine down and out new bearings in it and it’s doing the same thing. So I’m thinking it’s an electronic problem not mechanical but I could be wrong. They are gm ls coils. I’m waiting on a part for my cam sync so I’m currently running wasted spark until the part comes in
I am also using LS coils, but wasted spark with a trigger sensor on the flywheel.
Re: misfire
I have to apologize, the valves were way out of adjustment. it seems to be better now but it still has a sporadic misfire, when its not misfiring it idles perfect. When it misfires it jumps around i.e misfires on different cylinders. It almost acts like a vacuum leak but it isn't. I'm not sure what else to look for. i do appreciate all the help so far.
Re: misfire
Have you checked the cap, rotor and the dist. itself? Stories I could tell you on them .
Just a thought.
Just a thought.
Re: misfire
its fuel injected there isn't a distributor
Re: misfire
What you are describing is something like that part of the ignition system can cause. Had similar problems like that before and those parts ended up being the problem!
- Jadewombat
Re: misfire
*Edited* try doing some data collection also. It should show up on cylinder #1 if it's just that.
Then try swapping smart coils with another cylinder, etc.<<
Sorry, I had a couple of drinks. Compression check?
