more front suspenion building
Posted: Wed Aug 03, 2011 6:41 pm
Hello.
I have been working on part one of two for my front suspension (part two involves big brakes and new balljoints...)
My previous setup was simply chopped bmw springs with NOS strut inserts. Worked OK, and seemed to be an improvement handling wise over the stock cut springs in place from the previous owner. The issues with this setup were stiffness (as reported from my passengers, I dont mind a harsh ride), and the fact that the spring was too short resulting in the spring unseating in the perches when jacked up.
Anyways, I decided to build my front suspension mainly because I was lazy in letting the car down one say and the spring came half out of one of the perches, giving symptoms of a seized strut mount.
I used rabbit strut inserts by bilstein,
Sport Series (P30-0032-M1) Front (34-184530)
with this (slightly modified) strut mount : http://www.klaindustries.net/strtmnt/strtmnt.htm
and some spacers I had machined.
Spacers, you can also see the large nut that I had to have bored for the larger piston of the bilsteins. I also had the rabbit retaining nut that came with the struts machined to fit inside the strut tube so the 412 retainer would clamp on it.
Difference in the top of the struts and length
Mounts after first mods, right one is modified so aluminum is on bottom, to clear the spring seat. This lifts the car ~1"
Mounts ground to fit shock towers and studs installed in 412 bolt pattern
rabbit retainer with seal, machined so it fits inside the strut tube
Anyways, I used the chopped 412 front spring, and it was just long enough that with the rabbit insert (that is a bit shorter than the stock rabbit insert due to it being bileteins "sport" version) the spring was compressed about 1". The last guy cut from the stiffer side of the progressive spring, and so did I. I cut one additional coil but forgot to count how many were left :/
Then came the strut tower mods... 4 notches to clear the nuts on top of the strut mount. It is not a 100% bolt in, however I can still go back to stock.
So, dispite the solid mounts and high pressure monotube struts, the ride was much improved over the last setup. Alot is probably due to the fact that I was close to riding the bumpstops before, and none are required with bilsteins because they have build in bump stops.
My ride height is ~ .25" lower than with the bmw springs in the front. I estimate a 4-5" drop over stock 412 but its hard to say as I took a ROUGH measured against one of my parts cars. (and the 5" would include the drop due to slightly smaller tires on the front). It now rubs a bit on the fender over bumps on full lock. Ill get smaller tires once these wear out to fix that.
Also, I accidentally tested it against bottoming out at night in a construction zone. Hitting the equivalent of a 4" tall soft curb did not cause any bottoming out at about 55km/h.
Thanks for reading my rant, if anyone has any questions feel free to ask.
