2276 TURBO MEGASQUIRT BUILD
kubelguy13
Re: 2276 TURBO MEGASQUIRT BUILD
Post by kubelguy13 »
Turbo_Manx_Maniac wrote:Agree with TB, Dial indicator needs to be perfectly parallel with valve stem. A good way to mount your dial indicator is a plate bolted to the intake bolts.
Did you put any sealer under the head stud nuts?
No I did not put sealant under the head stud nuts. What would you recomend?
"Being ready is not what matters. What matters is winning after you get there."
kubelguy13
Here are my lift numbers with the dial indicator aligned to the valve stem.
#1
Inlet .485" PushRod 27.8cm
Exhaust .488" PR 27.8cm
#2
Inlet .485" PR 27.6cm
Exhaust .485" PR 27.6cm
#3
Inlet .485" PR 27.8cm
Exhaust .491" PR 27.8 cm
#4
Exhaust .491" PR 27.8cm
#2 was giving me smaller lift numbers originally so I shortened the push rod and lengthened the adjuster screw.
Turbo_Manx_Maniac
Post by Turbo_Manx_Maniac »
Permatex aviation sealer or something similar. Oil will eventually leak from the 4 head studs and 2 rocker studs inside the valvecover.
I accidentally Googled my Twitter. (And I liked it)
Humpty
Post by Humpty »
Great build happening here.... Looking forward to the next installment....
kubelguy13
Humpty wrote:Great build happening here.... Looking forward to the next installment....
Thanks Humpty. I can't wait for the next installment either. I haven't figured out how I'm going to cut all my pushrods to the exact lengths yet.
Humpty
Post by Humpty »
I do mine in a lathe.... I mark them then rough cut them first (hacksaw in a vise), then fit them up in the lathe and turn them down to the finished size... Not sure how else you'd do it.... But I'm sure there is a grassroots method out there.
capsoval
Post by capsoval »
I use a pipe cutter to cut mine, when I cant use Bugformances lathe. Works just fine.
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
turbobaja
Post by turbobaja »
For the cutting, I used a pipe cutter too. Nice, clean, square cuts. Just a little light file work to deburr the cut tube end. You want it nice and flat/square for the end to press down in and seat fully against the cut end without hitting any high spots.
Karl
DON'T QUIT
Post by Chip Birks »
I use an Easton Arrow Cutter, its super cool! Can set any length I want, then repeat it as many times as needed. http://www.thesamba.com/vw/classifieds/ ... ?id=954144
It also has stones for deburring inside and out.
bender
Post by bender »
Your build look's sweeet .. 8) ....
As a common practice for me, With a turbo build, I remove the part of the bronze guide that protrudes into the exaust port...Just my 2 cents
MarioVelotta
Post by MarioVelotta »
Well here is some good news for you buddy! Yours is on the right. Just have to tig it in :wink:
[email protected]
Humpty
Post by Humpty »
Hey Mario.... At what pos (º wise) are you placing the timing wheel?.... ie: the missing tooth is lined up with what point on the timing mark?
I have yet to fit the one you sent me a while back....
How's the drawings?
:wink:
kubelguy13
bender wrote:Your build look's sweeet .. 8) ....
Hey Bender
how do you remove it?With a carbide bit? do you smooth it out flush with the aluminum?
Thanks for the tip
kubelguy13
MarioVelotta wrote:Well here is some good news for you buddy! Yours is on the right. Just have to tig it in :wink:
Nice work. How much did you have to shave off the trigger wheel to fit my pulley?
bender
Post by bender »
Hey Bender
Thanks for the tip
yep.......Flush....Had some problems....had some unwanted paraphernalia in the turbo.........
Mario.....those wheel's look sick... 8)
