strut bearing/bush problem
Here's the place to start. Introduce yourself and your ride.
David Wan
Post by David Wan »
Hi
I have a july 1974 curve screen superbug.
I have jack up my front left wheel and take the pressure off the front spring and strut.
the metal disk underneath the strut top nut is touching the white plastic ring underneath it.
I think this means the rubber bushing needs replacement.
Can I still buy this part or do I have to buy the whole strut bearing assembly.? ( I think the bearing is no longer available)
I am wondering what everyone else is using to fix these problems .
thanks in advance
David Wan
