Fuel Systems that Feed our Turbo powered mills! (GALLERY)
Muffler Mike
Re: Fuel Systems that Feed our Turbo powered mills! (GALLERY
Post by Muffler Mike »
Don't remember if I shared this before but a while ago I modified a stock tank. Hold 2 gallons and traps fuel at pick up during acceleration
Wally
Post by Wally »
Subtle!
marzano
Post by marzano »
Kalle wrote:Before I installed the Aeromotive pump I used to have a Walbro GS340 (255l/ph) in my tank. Quiet, small and light but it did not supply enough fuel:
Same fuel lines as I`m using on the Aeromotive pump.
Best rgs
BeetleBug
So great!
People, where can I find it?
Thanks
marzano
Post by marzano »
Ok.. I found
GPA-Series Fuel Pumps
[]s
fastvwman
Post by fastvwman »
MarioVelotta
Post by MarioVelotta »
Sexy, but that spring looks like it would help hold it full open also :)
[email protected]
fastvwman
Post by fastvwman »
the spring helps keep it all the way open or closed. instead of halfway accidentally. :)
Marty
Post by Marty »
fastvwman wrote:the spring helps keep it all the way open or closed. instead of halfway accidentally. :)
EXACTLY!
MarioVelotta
I guess I've never wanted a spring to hold my throttle wide open. Am I alone here?
[email protected]
fastvwman
Post by fastvwman »
MarioVelotta wrote:I guess I've never wanted a spring to hold my throttle wide open. Am I alone here?
thats the fuel pump shut off. NOT the throttle. :lol:
MarioVelotta
Haha! Got me good :)
[email protected]
Fiatdude
Post by Fiatdude »
I put some bungs on the bottom of the tank then put the pump up front -- 100 mic prefilter there's a 10 mic hidden back under the tank
Hard lines ran to the back
turboboy
Post by turboboy »
Howdy
So guys what you recommend for a draw through for a 250 to 300 hp motor
Holley red or blue pump or something similar and quieter would be nice ?
pressure reg . just the standard dead head or bleed off style
cheers
Rich
Fiatdude
Post by Fiatdude »
Damn -- Whe you look at Marty's stuff, it makes mine look like chit , so what do you do -- you go buy some of Marty's stuff LOL
Still cleaning things up after fabing them up but basically
2 -5/8" fuel lines back to front
Front cell with pumps and filters
Marty's stuff and my chit LOL
Devastator
Post by Devastator »
turboboy wrote:Howdy
cheers
Rich
EFI?
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
