1967 VW bug, $6000
Located in Brea, CA
runs and drives great
all parts new within last 3 years
Rear:
fresh 1914, about 200 miles
full flowed with remote HP1 filter, AN fittings and steel braided hose
Single Weber 44
ceramic coated exhaust
Saco pulleys
009 Bosch Distributor
Rancho ProStreet swing axle, about 200 miles
Heavy duty side cover
new mounts and bushings
Empi trigger shifter
Rear shock tower/ frame horn brace, all chromoly with 5/8 ths rod ends
All fresh brake parts in the rear, lines, drums, shoes, wheel cylinders
new shocks
Front end:
3" narrowed beam with adjusters, CB drop spindles and disk brakes
new master cylinder and lines
new steering box and stabilizer
new gas tank
new shocks
Other:
Chromed American Eagle 5 Spoke Wheels
Yokohama tires
Front: 185/55 r15
Rear: 215/60 r15
Roof rack
Interior is stripped, pans were stripped and undercoated.
Has late model high back seats, driver's side is ripped
Have rear seat also, but not installed
Body is really straight with no rust, always been a California car
Radio hole is uncut
Autometer Tach, oil pressure, oil temperature, and volt gauge
Billet side steps
Crow lap belts
all electronics work except for the wipers
Wiring is in decent shape
