What did you do to your turbo today?
Vee Dub Nut
Re: What did you do to your turbo today?
Post by Vee Dub Nut »
You need to do it the right way and take your crank to a machine shop that has a bearing separator and a press (if you we're only closer I could do it for you)... It would sure suck to screw something up trying to pull it off at home
Fightin' Texas Aggie Class of 2006
67 Beetle
74 Transporter (SOHC EJ25)
See all my VW pics on Instagram @ vee_dub_nut
turbobaja
Post by turbobaja »
Mapp should get'r'done. Like Steve said, don't heat it for too long, then quick with the puller and zap it with an impact (lube those threads, or else though :( )
Karl
DON'T QUIT
bazibbo
Post by bazibbo »
Had a big binge and fitted both my remote oil cooler, filter and chargecooler to my bug. There's an awfull lot of plumbing going on above my gearbox...
_____________________________________________________________________________
'71 1302s 1914 EFI chargecooled turbo
My old build thread http://www.shoptalkforums.com/viewtopic ... 3&t=138297
Muffler Mike
Post by Muffler Mike »
it happened saturday. after trying to remember back, this weekend i finally turned my transmission into a bag of marbles. the first time for a gear failure since 2001 if i remember right
MarioVelotta
Post by MarioVelotta »
Oh that is a bummer... 10 years is damn good though
[email protected]
Post by Chip Birks »
I finally got to drive mine again! New O2 sensor showed up in the morning, got it installed in the afternoon and drove it to work that night! Took it pretty easy as I'm just building the 91 octane tune for it now. Saw 11psi, feels pretty good :twisted: Its definitely slower to come into boost while driving in higher gears than it was with the smaller cam/turbo combo. But it hits hard when it does come.
shag55
Post by shag55 »
That trans has seen it's fair share of launches Mike! Now how do I get my car to leave like yours????
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
[email protected]
Facebook at SL 1 racing
shag55 wrote:That trans has seen it's fair share of launches Mike! Now how do I get my car to leave like yours????
TWO STEP!!! LOL!
Muffler Mike
more boost, LOL
not sure if im the right.person to ask since i tend to go against the turbo grain with short 24 tall tire and short 4.11 first.
two step helps if your not using it, retarding timing on two step helps more, clutch slip, data logging, and especially an o2 sensor to see if car is a pig off the line. suspension and
shock settimgs.
not sure if that was a serious question or not but theres some
shag55
Post by shag55 »
Very serious! I'm going to try some 24" slicks as my tall gearing ain't helping things with my HP and weight. I will also work on data logging and launch controll.
What's next?
[email protected]
Muffler Mike
i have old school t4 turbo currently running its 12th season, not super whammy efficient, on journal bearings , and the biggest thing that woke my stuff up was a smalller exhaust housing.
Marty
Post by Marty »
Muffler Mike wrote: and the biggest thing that woke my stuff up was a smalller exhaust housing.
:wink:
turboblue
Post by turboblue »
Bought it a new set of pistons......... :mrgreen:
Image Image
Gary
Turbo VW Sand Drag Buggy
2013 Polaris Ranger 4x4
My Website
Shop Facebook Page
MarioVelotta
Image Image
Is there a purpose for the groove between rings?
[email protected]
Stripped66
Post by Stripped66 »
:wink:
The exhaust housing is the biggest, er smallest, thing holding my engine back :x
