Cracked that puppy open (I was feeling really brave). Todd sent me a pinion setup tool, so I figured I would try to do this whole thing myself...
I made a "plaster" mold of the left case to use as a gauge to clearance the right case side.
No problemo!RonW wrote:somebody's been busy! looks good. if/when i end up going with the suby tranny, would love to tap into your experience/expertise then if you don't mind
Oh crap...that one looks like it would be difficult to get to...you have to take off that huge nut to get to it.56SemaRag wrote:The double taper. The one that the shims sit on and has the four mounting bolt holes.
ShopTalk folks have the coolest toys.ambrynmc wrote:I even put the spiral gears in a vibratory tumbler for a half hour (need to go in for longer).
