When I was still asperated running a Web251 cam and Redline 50mm ITB's, I would register 7kpa higher than ambient air above 5500 rpm. That's just a hair over 1 lb of 'boost'! Straight IDF manifolds on CE 48x38 heads.
Thanks for the replies guys It,s drag race only, 5500-8500 RPM but if was to really put a 50mm or bigger t body on this motor isnt the port velocity going to take a massive nose dive ? As I mentioned above the motor runs its fastest times with 42 vents in the ida,s ( yes it looses power with 44's ......)
I guess the first thing I will do is slap a few combinations of t body bore sizes on the flow bench and measure some velocities with the Pitot tubes, comparing to what we see with the 42 vent ida's and work from there.
Eaallred wrote:When I was still asperated running a Web251 cam and Redline 50mm ITB's, I would register 7kpa higher than ambient air above 5500 rpm. That's just a hair over 1 lb of 'boost'! Straight IDF manifolds on CE 48x38 heads.
Nice!
It probably makes best power due to emulsification not air speed. I'd go for the 50s myself.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
