Common car fuel pumps?
Bruce.m
Re: Common car fuel pumps?
Post by Bruce.m »
Try Tracy Tools (Google it) for NPT taps
andy198712
Post by andy198712 »
Bruce.m wrote:Try Tracy Tools (Google it) for NPT taps
£6 not bad!! Will look up postage tomorrow at home :)
Thanks!
Clonebug
Post by Clonebug »
Just make sure you can get NPT brass tee's.
andy198712
Clonebug wrote:Just make sure you can get NPT brass tee's.
I'm also wondering if 1/4NPT is like 1/4BSP ect
Or i just buy a swirl tank, seen VW made one from an old golf or something? had an IN, VENT, OUT, RETURN .... can use an 8mm outlet tank piece maybe...
Clonebug
Post by Clonebug »
That would be too easy :lol: :lol: ....if you could find one.
andy198712
Clonebug wrote:That would be too easy :lol: :lol: ....if you could find one.
Just thought, what if I could walk into the dealer and buy one! Doubt I'd be THAT lucky mind!!
Clonebug
Post by Clonebug »
I think it was Pile that said they were available at the local "FLAPS".
You could try there too.
Didn't the VW Fox use them???
andy198712
will have to look into it, need a uk suppler also. seems as easy route to go though!!
8)
andy198712
anyone know what VW called these things?
squeakie
Post by squeakie »
I don't know if these are any good (quality), but the price seems right:
http://www.ebay.com/itm/2L-Universal-Al ... 86&vxp=mtr
raygreenwood
Post by raygreenwood »
andy198712 wrote:anyone know what VW called these things?
Are you talking about the fuel pressure accumulator from a CIS injected car?
I think I mentioned at some point using the plastic sump recirc tank off later Golfs/cabbies/Fox etc.
I think the nomenclature was "filter" or something equally idiotic for a ~transparent hollow plastic enclosure with a bunch of tubes sticking out..
andy198712
They turned out to be pretty pricey here in the UK new, around £80 which is about $150??
What about that vent in the corner of the tank, as you look in under the bonet from the front of the car its bottom right, couldn't i just put my return into that??
andy198712
anyone tried that? or the port in the filler neck? looking to get this rolling next month :)
Jadewombat
Post by Jadewombat »
I use a Bosch pump off a mid-70s VW bus and the fuel filter. The inlet side of the filter is 6mm I think? and 8mm outlet?? It's smaller on the inlet side than the outlet though.
