Need to adjust valves on my 1600 dp.
rrb6699
Post by rrb6699 »
ive done this once before and as I recall, the car didnt run very well. I gapped to .006 and thought I had tdc. I could look it up but, the advice is so good here, I just want to get some tips to insure I do it right.
car is running perfect btw except I can hear a valve or two tapping.
TIA,
RR
RR
1972 Restoration Project.
aussiebug
Re: Need to adjust valves on my 1600 dp.
Post by aussiebug »
Here's a complete tune-up guide including valve adjustments.
www.vw-resource.com/30pict2.html if you engine has a carb with a single adjusting screw in the left side.
www.vw-resource.com/34pict3.html if your carb has two adjusting screws in the left side.
The rest is similar for all engines.
Regards
Rob
Rob and Dave's aircooled VW pages
Repairs and Maintenance for the home mechanic
www.vw-resource.com
rrb6699
Post by rrb6699 »
the carb is a weber. there is an adjusting screw on the throttle linkage and one on top left side of the carb that you can only reach with a long flathead from the right side. it looks like its hooked to a small diaphram box.
the carb is a Weber 2bbl #-32 36DFAV.
I dont have the shop manual because its on my notebook and its broke right now. but I cannot find any adjusting screws in the carb body itself.
why would valve adjustments have anything to do with the carb anyway?
RR
aussiebug
Post by aussiebug »
The valve adjustment does not have anything to do with the carb.
I wrote those articles to cover the two different stock carb types, and then as I said above, the rest of the articles are the same, meaning in your case, the valve adjustment section is the same.
There is a correct sequence for doing a full tune up, starting with the engine cold and ending with it hot.
You can use either article and just ignore the carb tune up section, since yours is not a stick solex.
Regards
Rob
www.vw-resource.com
rrb6699
Post by rrb6699 »
ok thanks! appreciate that.
RR
