Here is the combo and I'm trying to figure out what cam to use. I want a fun weekend warrior car that I could easily drive to San Diego from AZ.
DRD 044 L6 42x37 heads with match ported big beef IDF manifolds with 48IDF's
82x94
1 5/8 merged header with turbo muffler
010 distributor triggering MSD ignition
fully prepped AS41 or CB aluminum case
fully doghouse cooling(all tin) with additional fan-assisted cooler if necessary
compression open will decide with cam (I am not afraid of high compression if parts work together)
deep sump
26mm pump
ALL Hoover mods done to the case/rockers, etc.
CB 28mm lightweight lifters
I have every size of ratio rocker at my disposal.
chambers are standard bathtub 044 chambers
I will have an Innovate wideband mounted to the dash to tune the engine.
Car is a '67 Type 1 with stock gearing.
Any initial get-me-close thoughts on jetting? Vents, jets, e-tubes, etc?
Thoughts on cam?
Thanks!!!
Matt
Here is a picture of the heads-
