Using Bugpak Hideaway muffler for Suby bug
andk5591
Post by andk5591 »
Still in planning stages, but it came to me that something like a Bug Pak Hideaway style muffler (that tuck under passeneger fender) would be a good solution for a non-turbo conversion. Been done?
72marinablue
Re: Using Bugpak Hideaway muffler for Suby bug
Post by 72marinablue »
I loved that muffler on my stock engine. My only complaint is that it wouldn't fit with my rear disk brake conversion.
GS guy
Post by GS guy »
I'm thinking the tubing diameter of the hideaway might be a tad small for a 2+L Suby? I know Magnaflow makes a muffler with inlet and outlet on the same end of the can - so must make a U-turn at the other end. This could be set up the same as a hideaway, but less tubing! The Magnaflows usually come in various tubing sizes as well, so you can pick one that matches your exhaust tubing diameter.
https://www.magnaflow.com/products?partNumber=14210
I used one of those bugpack setups on my squareback with a T4, cut and relocated so it laid down flat tucked up by the valve cover.
(There is no room behind the tires on a T3, the engine cooling air channels occupy that space)
Agreed, that style of muffler doesn't flow as well, but you can copy a good idea with a Magnaflow it may work.
IIRC the bugpack used 2" tubing so that shouldn't be a showstopper, probably worth trying it.
andk5591
Post by andk5591 »
When I get closer, I'll take some measurements. One of the things that I will take into account is the reduced back pressure in the new system relative to as installed in the Imprezza. I mean, I will have 2 less catalytic converters and about 10' less tubing.
Post by Chip Birks »
This is what I did. Obviously not subie. But similar to hide a way idea. Disc brakes, 2.5" straight through. Nice and quiet, but still allows for awesome performance.
panel
Post by panel »
That's the same Magnaflow I use in my Subie conversion.
panel wrote:That's the same Magnaflow I use in my Subie conversion.
I've been very impressed with it. Stainless, good flow, and quiet. What more can you ask for?
That's the ~same muffler layout I ended up with on my Bursch exhaust under my T4-swapped square, using a tweaked Bugpack hide-away setup. It worked OK but muffler didn't last long.
That Magnaflow have a part# or know the dimensions offhand?
panel
Post by panel »
GS's post above is it I think.
Do'h
I poked around on Magnaflows website for 5 minutes and never found it.
Gonna take a ruler to the square and see how that might work out.
Currently has to fit under a rear crossbar but I plan for that to go away RSN.
andy198712
Post by andy198712 »
i want a similar muffler but getting one in the uk isn't as easy as that, and they like up the price!
