Can anyone identify these Subaru harness parts?
Urnge74
Post by Urnge74 »
I'm trying to lay out my my EJ22 (90-91 I think) harness and label everything plus omit things that are not needed. For conversion into a 74 beetle. There are a few wires I am not sure what they are or what I am supposed to do with
1 large plastic gray block - all wires have been cut except the red white black etc in bottom corner. (I think this ties into the plugs that go to engine cam/crank sensors) Can I omit the block and splice the uncut wires together?
2 two large white wires that go into a black plug. What needs to be done to this end, white wires look to go to alternator
3 two small black wires that end on a squared off ring connector
panel
Re: Can anyone identify these Subaru harness parts?
Post by panel »
Looks to me you're right. The two white wires are the positive off the alt. Same as mine and the squared ring connector looks to be grounds.
