Let's play name that tool
- Jadewombat
I found this and I'm not sure what it's used for. Any ideas?
- sideshow
Re: Let's play name that tool
Heli-coil installer
66brm
Tyre valve removal tool
- sideshow
Yeah, that maybe originally the tire tool.
https://www.bing.com/images/search?q=he ... &FORM=IGRE
It could be but I am not sure it is. Because of the handle it looks to be a later design than I have used might be deceiving me but the narrowing of the end of the tool makes is plausible for small helicoils. You put the bent end in the tool, screw it in then smack the end to break off the bent end of the helicoil opening up the insert for longer bolts to go through.
https://www.bing.com/images/search?q=sc ... &FORM=IGRE
I don't think it is a Schrader valve installation tool because of the narrow slot leading to a larger drilled hole. What I found on line isn't like what the picture shows.
http://www.lifeandhome.com/monkey-grip- ... oup%20%231
There used to be a valve cap that had the proper ends so you could use an old tubeless valve stem with the cap on to remove the Schrader Valve.
- SCOTTRODS
This looks exactly like the tool... Schrader Valve tool. But yours looks modified. I do believe this is a match for the one in the original pictureother than the modified slot.
- SCOTTRODS
Other than that... does it have any other markings like a Patent number or a part number?
- Jadewombat
Yeah, that's it. It has a name of dillvalves.com on the side of it.
Dill mg. #5411. I think it is on page 28 on their catalog but it is a valve core screwdriver. Hmmm!
66brm
So..... What did I win
- SCOTTRODS
Your turn to come up with another tool that we get to identify... The weirder the better. This is a learning thing, not a winning thing...LOL
66brm
OK pic coming, I know what it is, BTW to help I'm a diesel mechanic with a military background
- Jadewombat
Thanks again. I don't know if I'll ever use it, but it won't take up much space in the tool drawer.
- SCOTTRODS
I have a couple of 'em... mine are old Snap-On tools... had 'em for a while.
- perrib
I had one of those. It came from an auto ac supply house. I bought mine 25 years ago.
