Do you guys machine the rods when you go on arp s
I never did that when i replaced the stock ones with fresh used stock ones
If the stretch readings were to much
Just punched them in
And never had anny issues gr henri
RIP WBX
Re: RIP WBX
Judging by the chamber shape, in the above pics I see sunk valves here.
For comparison, side by side
Sunk valve and stock valve chamber, the German stocker is 18cc and bigger in chamber volume than often quoted, they came from a brand new factory MV 2.1, suggesting to me they supplied the bigger chambers on MV motors, other heads I've CC'd, have been only 14cc.
Last edited by buildabiggerboxer on Wed Jan 06, 2016 3:16 pm, edited 1 time in total.
Re: RIP WBX
They go right in with no machining, normal common sense applies to check for ovaled ends, if they go in loose, the rods are fretted and a throw away, ive had them were the cap just falls off the bolts, scrap them, there's nothing wrong with new 2.1 stretch bolts either, just stretch them 003" and done, usually that's about 30/32 lb/in.mr horsepower wrote:Do you guys machine the rods when you go on arp s
Re: RIP WBX
It lives.In January 2018 the engine turns on
My friend Jürgen and I built it together in November,December,again with his cam http://www.frisiersalon-nowak.de ,lifter and pushhrods from Thorsten Piper http://www.tp-technologie.de/, rods from cb perfomance with new made bigger bushings,exhaust A1 sidewinder,carbs weber
[BBvideo=560,315]https://www.youtube.com/watch?v=5cs86YeOLug[/BBvideo]
[BBvideo=560,315]https://www.youtube.com/watch?v=0lbC3cadQLY[/BBvideo]
The last saturday i change the jettings on the carbs and wrote a new curve for the 123 usb ignition.
engine revs very quick
180hp must be reachabel
Cheers from good old germany
Turner
Turner
