40mm Weber IDF draw through turbo intake?
JesterGrin_1
Post by JesterGrin_1 »
I have been reseraching doing a cheap Turbo build on a 1600 single port and happen to have a pair of 40MM downdraft Weber carbs but I have been reading here and can not find anything for a draw through downdraft Weber carb set up? Mostly 2 and 4 barrel holley intakes.
Thank You for any help on this. :)
V8Nate
Re: 40mm Weber IDF draw through turbo intake?
Post by V8Nate »
You are probably going to have to make your own intake. I've seen plenty of side draft weber intakes I dont know if you could get one for a side draft(if it has the same flange) and use a 90° coupler and support brackets for the carb of course
Sent from my SM-N950U using Tapatalk
JesterGrin_1
I was afraid of that. :( But Thank You for the reply. :)
V8Nate
Post by V8Nate »
You bet
buguy
Post by buguy »
How bout buying some hats for them and blow through them? It's probably a better design anyway.
petew
Post by petew »
buguy wrote: Fri Oct 26, 2018 3:35 am How bout buying some hats for them and blow through them? It's probably a better design anyway.
This. Then you can use an intercooler and really help your motor. ;)
buguy
Post by buguy »
I wonder how much, if any, an intercooler is compared to the icing affect of draw through. My intake was COLD When I had it running.
I guess I could have grabbed the intake after the turbo to see how hot it was.
I've been reading about how some people inject water into the turbos to cool the compressed air too. Had never heard of that before.
V8Nate
Post by V8Nate »
buguy wrote:How bout buying some hats for them and blow through them? It's probably a better design anyway.
It's a single port, I haven't seen idf single port intakes before
buguy
Post by buguy »
Oh. Well....I guess your limited then.
sideshow
Post by sideshow »
As a blow through one could just use solex 34 center section adapter like;
http://www2.cip1.com/ProductDetails.asp ... e=C13-3237
to make one IDF fit like is done on dual ports.
V8Nate
Post by V8Nate »
Great idea sideshow!
JesterGrin_1
Thank You and heck I am sure many will be happy to see that adapter kit from a duel to a single port end casting kit. But I would still have to purchase the center section and a hat.
I would have thought the draw through set up would be cheaper and easier to do?
Or heck I may have to either think about biting the bullet and getting a Holley 390CFm 4 barrel or one of the Holley 2 barrel carbs and run with that or of course make my own intake for the Weber.
buguy
Post by buguy »
Draw through will be cheaper and easier. And making an intake is fairly easy to do. But if you did go with some other carb you would be able buy something pre made if you don't have the time or ability to make one yourself. Personally I like the Holley stuff because I can get parts anywhere. Very simple to work with.
A 2 barrel Holley is easier to set up than a 4 barrel too in my opinion. If I we're starting fresh (and I may anyway) I have think I would try one of those Percy's adjust a jets too. Would make life way mor simple tuning. Also you have to have to have to get a wideband. I have a few extra Holley carbs if you decide to go that route.
andy198712
Post by andy198712 »
buguy wrote: Fri Oct 26, 2018 9:29 am I wonder how much, if any, an intercooler is compared to the icing affect of draw through. My intake was COLD When I had it running.
also called meth injection 8)
buguy
Post by buguy »
Yeah I had just never heard of using it to spray specifically into the turbo to cool things.
