Got my ej20t
turboedbug
Re: Got my ej20t
Post by turboedbug »
dlamyle wrote:
bad62bug wrote: ↑Fri Nov 09, 2018 1:23 pm Nice thanks for the info.
Your Ghia must fly, have you taken down the 1/4 mile yet
She really does fly. No runs yet. I need to build a cage and stop breaking things. I broke a transmission mounting bolt and I'm pretty sure that caused the shift rod to smack the torsion tube and crack the nose. And my clutch is slipping. I'll be pulling the engine for the 5th time this winter...
Are ya running the subaru trans?
Sent from my SM-N960U using Tapatalk
Turbo!
dlamyle
Re: Got my ej20t
Post by dlamyle »
turboedbug wrote: ↑Mon Nov 12, 2018 4:50 pmAre ya running the subaru trans?
I am. I've built it up with PPG gears and an OBX LSD. I've been running an Exedy twin disc clutch but I think its time to swap that out. It's a bit noisy and I'm not sure why its slipping but it is at full boost. I'll give it a good look when I get it out.
1968 Karmann Ghia, JDM EJ205, Subarugears, OBX LSD, Blouch 16g XTR, Killer B Headers, DW 750cc, Meth Inj, Cobb AP w/Mach V 22psi Dyno tune (332whp)
Videos
Build Thread
turboedbug
Re: Got my ej20t
Man sounds like fun other than breaking stuff hahahah.
Turbo!
turboedbug
Re: Got my ej20t
So i didnt do a whole lot on the car today.
Waiting on the trans parts so i can finish that stage of the build.
My moms beetle took most of the day sorting the wiring that was done by the previous owner.
I did however bend up some 1" emt conduit for the coolant lines. This was done in the past but i didnt like how sloppy i did it.
This time around i took my time. Its not finishedImageImageImage
Turbo!
dlamyle
Re: Got my ej20t
Post by dlamyle »
turboedbug wrote: ↑Tue Nov 13, 2018 3:35 pm
you just had to say something about "breaking stuff" one week later... :evil: :evil: :evil:
Videos
Build Thread
turboedbug
Re: Got my ej20t
Damn man!
How hard ya pushing it?
Turbo!
turboedbug
Re: Got my ej20t
Since tapatalk is being stupid heres a video
https://m.youtube.com/watch?v=I7BS0qQYuH4
Turbo!
turboedbug
Re: Got my ej20t
Today i am scewing around with the trans.
I am having an issue so in neutral both the input shaft and pinion shaft spin together.
So beings in neutral that shouldnt be happening.
I am thinking this gear with the yellow arrow is stuck. Shouldnt this spin freely?
Any input would be really appreciated Image
Turbo!
turboedbug
Re: Got my ej20t
Well i pulled the pinion shaft back out and the second gear spins just fine...... wierd
The pinion shaft is a super tight fit i am thinkinking this might be causing it to lock up the bearings on second gear.
Has anyone seen this before?
Turbo!
4agedub
Re: Got my ej20t
Post by 4agedub »
dlamyle wrote: ↑Tue Nov 27, 2018 6:04 am
Have you received the uprated R/P yet? How did the old one break?? Was it under hard acceleration or launch?
VW Beetle 1303 EJ20T Subarugears Circuit Racer
VW Beetle 2332cc 200hp N/A Circuit Racer
VW Beetle 1969 2666cc Turbo Road Toy
dlamyle
Re: Got my ej20t
Post by dlamyle »
4agedub wrote: ↑Mon Apr 08, 2019 6:43 am Have you received the uprated R/P yet? How did the old one break?? Was it under hard acceleration or launch?
I have the uprated R/P in now. Still breaking in a new (softer) clutch so no verdict on the set up yet. I think it will be fine. The other one broke after shifting into 2nd while spooling a bit of boost. Nothing crazy but spirited. I had an Exedy twin disc clutch that possibly transferred too much shock. This is the last time I will do this trans. If it fails I'm building a mid engine 6sp Ghia.
Videos
Build Thread
bad62bug
Re: Got my ej20t
Post by bad62bug »
Killed my subarugears Trans
Looks like the head of the pinion shaft twisted off and the shaft shot out the nose cone.
dlamyle
Re: Got my ej20t
Post by dlamyle »
I feel your pain 100%! I'm not even going to ask what you were doing or how you were driving because it shouldn't matter. I just wish I were more surprised...
Videos
Build Thread
bad62bug
Re: Got my ej20t
Post by bad62bug »
I drive hard and have about 1000 miles and about 14 1/4 mile passes 1.8 to 2.0 second 60 foot, pre loading the trans no dropping the clutch, street tires. this happened on the street accelerating in second.
Last year I was running 14 psi , 12.59 1/4.this year i have new turbo with air to water cooler, pulling much harder this year. Blouch TD05H-16GXT 7cm^2 Turbo Billet Wheel.
Todd sent out the new parts yesterday for free no ? asked, so i'm real happy with that, hopefully all goes well and i have it back on the road this weekend.
Most places wouldn't give a rats ass, it's great he stands behind his stuff. :mrgreen:
turboedbug
Re: Got my ej20t
Thats awesome todd is hooking ya up.
That means alot.
Turbo!
