2450 (78mm x 100mm) engine build
Eddie010
Re: 2400 engine build
Post by Eddie010 »
Wally wrote: ↑Sat Nov 23, 2019 5:00 am Well done! Those lifters are awesome, I use them in both my 1200Challenger and type 4 engine.
Walter,
What kind of clearance do you have between the lifter and cam?
I read somewhere that it should be 1mm.
But can t find any reference.
Thanks in advance.
Wally
Post by Wally »
It depends also a little on the base circle and camlift, but at least 1 mm seems fine to me too.
Eddie010
Post by Eddie010 »
Thanks for that info.
Have it on 1mm now, so will keep that.
Eddie010
Post by Eddie010 »
Yet another question, I like to install the CSP Type 1 10mm chromoly head studs, but I can not find casesavers from M12x1.5 to M10.
Does somebody sell those?
I can find the casesavers to M8, but then the question is are those head studs strong enough for my set up?
Thanks in regards
Tony Z
Post by Tony Z »
I think the geometry of a M12x1.5 to M10 case saver will mean that it doesnt exist.
What I mean is that at its narrowest (thread root) the casesaver will be 10.5mm in diameter. Then you still want to tap in a 10mm thread under it. This will leave (at best) a wall thickness of 0.25mm (0.01")
You might be able to use a M10 helicoil if thats the direction you want to go.
Clatter
Post by Clatter »
You can use T1 head studs on a T4??
I always thought they were different lengths...
Eddie010
Post by Eddie010 »
Clatter wrote: ↑Thu Dec 05, 2019 7:06 pm You can use T1 head studs on a T4??
Yes, you can make 1 set out of 2. and cut them to lenght.
but not sure yet, if I am going to do that
MegaRookie
Post by MegaRookie »
AA is also selling head stud kits for T4 engines. They are not on their website and I dunno if they have stock length, but last week I installed my (stroker) head stud kit. Nice quality with ARP nuts. :D
Just send them an email, and you know!
Mark
Eddie010
Post by Eddie010 »
Ok thanks Mark for that,
Will give that a try.
Wally
Post by Wally »
OTOH, as long as you only need stock length and/or not turbo the engine, aftermarket head studs really aren't needed with a type 4 imo.
Eddie010
Post by Eddie010 »
Thanks for al the info guys
Eddie010
Post by Eddie010 »
Noticed something new the other day, the oil pick up tube from a 1700 and 1800 engine are longer
on pump side then the ones from a 2000 bus engine.
They are not interchangeable.
Eddie010
Post by Eddie010 »
Can somebody tell the brand of these Nickies?
They are all aluminium. (no Biral)
These are the only markings I can find.
These are 100mm ones
Head size 114.75 mm
Case size 108.52 mm
Wally
Post by Wally »
Photo link doesn't work..
Correction, now they do ;-) Nickies is trademark for LNengineering nikasils iirc... those are not LN.
Could be QSC ?
Eddie010
Post by Eddie010 »
Wally wrote: ↑Fri Mar 06, 2020 4:32 am Could be QSC ?
Are those any good Walter?
Ps they are all aluminium. (no biral)
