DCNF throttle bodies...
ecksrash
Post by ecksrash »
Have any of you EFI guys used a DCNF style throttle body? I'm curious to know which set you used and why. From the quick research I have done, there are only three manufacturers for this style of throttle body....Jenvey, Borla(TWM), and Weber/Redline. I'm really looking at the throttle arms and how to adapt to a VW type 1 throttle linkage. Any info will be appreciated....
Wally
Re: DCNF throttle bodies...
Post by Wally »
Buddy of mine in Germany used the Jenvey 40mm set on his 1200 Challenge Motor. They look awesome!
Other then that I really can't answer any of your questions.. sorry.
I would like a set myself still though, unfortunately they are pretty $$...
ecksrash
Post by ecksrash »
Thanks for the info... I'm looking at these for an option to feed a 2332. I just need to find a set of Berg type 1 DCNF manifolds.
Wally
Post by Wally »
Sold some stuff and got a set of Jenvey DCNF's in 40mm because I could get these awesome (custom one-off's, not for sale) intakes 8)
Its for the 1200 N/A project :mrgreen:
Max Welton
Post by Max Welton »
Subscribed 8)
Max
Wally
Post by Wally »
Since Max has subscribed I felt obliged to update a little.. :P
Super proud of this as there is no airfilter for sale anywhere. I made these from a set of round Pipercross filters that I simply cut with scissors (spelling?) and glued together again with superglue :mrgreen:
The engine is in my buggy, but this 1192cc is so short (6mm flycut into 043 welded heads) that it would fit in any bug with these manifolds anyways.
Building a header and exhaust system for this atm, trying to keep equal length as much as possible and still allow for proper spark following at the 4-1 piece.
Its a crazy and totally useless undertaking to do all this on a 1192cc, but we have a dyno Challenge for 1200 engines each year here and of course I try to win the N/A class :-)
Paul H
Post by Paul H »
Was looking to make a similar intake for my bus with fabricated manifold with individual 36mm throttles on 70mm centres and much longer runners
I think the DCNF are 48mm centres
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
Wally
Post by Wally »
Yeah, longer runners in the manifold would probably be better for torque, but these were as is. And it keeps the engine somewhat less wide (although not a problem with this platform (Buggy)).
Still, longer stacks could help a little too was the idea, so had these printed in 10cm (4") height:
Ephry73
Post by Ephry73 »
Love it
