Thoughts on cam grind
Need some opinions on this camshaft for turbo. It's a Steve Long EXR304 on a 110 LSA. It's similar to the FK45 and 86b
I don't know the specs on the RLR PT1, but someone is trying to sell me on it over this.
Let me know
SLR EXR304
Lift w/ 1.4s 559 intake 559 exhaust
Adv Duration 304 @.050 262
Let me know
SLR EXR304
Re: Thoughts on cam grind
oof.. I didn't realize these forums were THIS dead
RIP
RIP
There not dead... just slow at times... maybe it is just deep thoughts going on.
Since I don't play with "puffed" engines I can't help much. I do run a high lift short duration cam on a normally asperated engine and that is to get "grunt" (torque). I don't think it will help with what you are running though.
- buguy
Kind of depends what your putting it on. Is it a 1200cc turbo or a 2442cc fire breathing dragon? What heads? What rpm are you wanting to run?
86B @112LC with 1.4 rockers is a really good Turbo cam
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
- Schweg
On what size engine?bug66 wrote:86B @112LC with 1.4 rockers is a really good Turbo cam
what Heads? street,off-road? I didn't fall for them so called 'turbo cams'
and my 2276 with a plane old FK 10 proves it,lol 25-28 mpg and runs 11's in the 1/4 mile
2165cc (94x78) with CB Wedgeport 44/37,5.
- buguy
Where was your shift point with that 86b? Curious as to what real world turbo rpm it turns.
I was too lazy to edit, but cut and paste my specs from a previous post. The only difference is I'm running MS3Pro Ult instead of the Holley EFI
Holley Dominator Standalone EFI
Holley sensors - MAP, IAT, CLT
Smart Coil CNP
Dubshop Crank Trigger Kit
Dubshop Cam Hall sensor
Accufab 2.75" TB w/ TPS
Holley EFI pump and regulator
Holley Peak and Hold injectors
Holley Boost control solenoid
NTK O2
Aluminum Super case 6 headstuds and sleeved lifters, flange cut, 411 mains
46x40 CB Comp Eliminators ported with Ferrea Alloy valves and beehive springs
Comp E injected manifolds
Jaycee long cylinders
AC.net C pin height Squishies 94mm
Scat 5.7 H beams
SLR coated scat cam followers
Shag billet wheeled T60-1
CE straight-cuts (no less than a work of ART)
Frozen boost liquid to air IC (in package tray)
Tial wastegate
Modified RLR Header
Sheet metal intake plenums w/ injector bosses
RLR Rev6
...and being built, 091 drag gearbox.
Smart Coil CNP
NTK O2
Scat 5.7 H beams
Tial wastegate
Modified RLR Header
RLR Rev6
If you are running a Shag turbo you might be better off asking him which cam he would recommend.....
- buguy
I'm gonna have to agree with Art here. That's no "run around town" build. Your in the high end of stuff and sounds like your looking for something serious.
That would depend on if he has recommended the correct turbo for this engine..
is has most likely a too small turbine.
Based on your valve size I would go for a tsc series cam. Or order a turbo cam from Skinne racing.
- buguy
I would say it's very unlikely Shag recommend the wrong turbo.
