Going under the knife
Re: Going under the knife
Dont hesitate a second to trim the plate the tire rubs//stop hits, only half of it is ever used.
I also very highly recommend modern foam bump stops, even if you dont slam the car.
I used a set from Ford racing for a late Mustang, I simply glued them on with Duro Plastic Welder.
Yes, the fronts are for struts... the pop on right over the stock bump stop nubbin. and work great.
If you do use/hit the foam bump stops you may not notice as they are very progressive in action.
I cant really comment on the SA setup but with IRS, flipping the spring plate bolts nut inside and trimming that bump stop plate I fit forged 8x16 et52.5 Porsche manhole cover rims with 245/50s. I admit I essentially tubbed the outer part of the inner fender to maintain full travel, but others have run 225/60s on 16x8s. There exist 16x8 et65 versions, and very good Porsche pattern t5 hubs and billet bj front hubs/brake setups exist off the shelf from CB et al.
Had to flare it a bit when I went to the early 944 rear suspension, and now it has 18x11s out back with 285/35s... Audi ur-quattro style pulled fenders hoping to finish next couple of weeks. Maintains full suspension travel.
(not suggesting the 944 rear susp or rediculous flares, I got bored and wondered one day if it would be easy to do flares that way... it was)
Appears a lot of the pics on the site have evaporated, will be back into it rsn so can take more if interested.
- Max Welton
Both heater channels are in. The body is (temporarily) sitting on the chassis and small adjustments are being made to ensure that everything is straight and true.
Placed another ISP order. They have straightened and powder-coated bumper brackets for about $40 each.
Bumpers are now at the strippers to get the backside cleaned.
Max
Max
- Max Welton
So. In three weeks the body goes to paint and I am in a bit of a fire drill. Robert took the steering column apart to have the tube and head unit powder-coated. The bag of steering column parts is incomplete. Near as I can tell i am missing the following:
https://www.vwispwest.com/pg94
113415589A Thrust Ring
113415587A Thrust Spring
113415593A Washer
111415521D Locking Shell
I don't know if there's more. The switch is the very nice ISP replacement switch which was working fine and is not 53 years old.
But I'm up against the calendar and I need something that works.
It has been suggested to me on the type3 list that a later type-3 column might work. Can anyone here speak to that?
Max
113415593A Washer
Max
One more thing you need to get is several rolls of wide, medium and narrow protection tape for when you violate assess holes (like the steering column through the firewall) in panels and other things like that. Also, when you start assembling, tape your mouth shut so when things don't the way you want them to you don't burn in hell .
So far, what I have seen in the pix is looking pretty good Max.
- Max Welton
Thanks for the laugh Lee!
Max
Max
- Max Welton
So we're getting very close to primering the car. Not trying to stay stock is liberating. For example, I'm interested in making this car as quiet as possible as well as protecting all that reconstructed metal. So we're applying ProCote, which is a brand of spray-on bedliner, to various parts of the car.
- Max Welton
- Max Welton
The jams are painted!
Max
Max
- Max Welton
Went down yesterday to check the gaps. There's a couple of things to fix but nothing serious. They are block-sanding now and Paint Guy says the main body will be painted and buffed in a couple of weeks.
And here's a purist alert. The car is mostly a 67 but the doors are from a 68.
The difference? Door handles.
Max
Max
- Max Welton
Things to fix:
First the cross-brace isn't quite straight.
Second, the piece behind the apron wasn't completely fixed on the drivers side.
My metal guy says he can fix these pretty easy.
Max
Max
- Max Welton
It's in the booth!
MaxYou do not have the required permissions to view the files attached to this post.
Lookin' so good I would hate to take it out on the road or around people with car doors ! Keep up the good work.
- Max Welton
I'll be parking in the far reaches of every lot.
Max
Max
- Max Welton
So the chassis and body have been separated, hopefully for the last time. With that cart I'll be able to work under the dash standing up.
Meanwhile the chassis is back in my barn to receive the engine, e-brake system, heater ducts and so forth. I should be able to charge the hydraulics by hanging a temporary brake fluid res. Detail everything.
Max
Max
