Thoughts on cam grind
Re: Thoughts on cam grind
It's a full size .68 a/r 60-1 billet wheel with 4" inlet (to4s compressor housing). Support up to 600hp.
How do you post pictures on this site? External web hosting/link?
What size turbine wheel?sixty5slug wrote: ↑Wed Nov 04, 2020 2:05 pm It's a full size .68 a/r 60-1 billet wheel with 4" inlet (to4s compressor housing). Support up to 600hp.
Fk10 you'll thank me later
A T60-1 has a 60mm inducer and 76.2 Exducer (compressor)carsten bb wrote: ↑Wed Nov 04, 2020 2:27 pmWhat size turbine wheel?sixty5slug wrote: ↑Wed Nov 04, 2020 2:05 pm It's a full size .68 a/r 60-1 billet wheel with 4" inlet (to4s compressor housing). Support up to 600hp.
Hi, yes I know the 60-1. What I am asking is the size of the turbine (exhaust) wheel.sixty5slug wrote: ↑Wed Nov 04, 2020 4:41 pmA T60-1 has a 60mm inducer and 76.2 Exducer (compressor)carsten bb wrote: ↑Wed Nov 04, 2020 2:27 pmWhat size turbine wheel?sixty5slug wrote: ↑Wed Nov 04, 2020 2:05 pm It's a full size .68 a/r 60-1 billet wheel with 4" inlet (to4s compressor housing). Support up to 600hp.
The cam did come from Shag. I'm mostly soliciting information from real world experience from folks who may have ran the EXR304 and/or the PTR1 from RLR in a similar combo. My last turbo motor had an FK8 which was fantastic. I'm building up my chassis to handle MUCH more power at this time. Won't be complete until mid to late next year projected.
Cam opinions are like ***holes......everyone has one.
It's interesting how many people on that other VW site can't make up their mind and end up buying 2-5 different cams before the build is even done and then leaving four of them on the shelf unused.
Smokey Unick said a specific cam is only perfect for a 300 rpm window....what 300 rpm window do you want it to be....was always the question.
I recommend getting his 3 book series and reading them.....especially the racing book.
That man packed 40 hours into a 24 hour day...........
My cam is boring...it's just a W-100.....
I'm stickin to my guns,I like Dave Kawells cam advice, fk8 for smallish motors and fk10 for the big ones
- panel
Yeah, I’ve read through most of it. I’m going to run the SLR cam. Motor will be finished long before the chassis. So I’ll report the output after tuning it on paradise’s chassis dyno.panel wrote: ↑Fri Nov 06, 2020 1:05 pm sixty5slug did you happen to read this ?
https://www.shoptalkforums.com/viewtopic.php?t=106178
