Hello everybody ,
I will be running a 2.5l engine with a front mounted oil cooler, and a deep sump, what oil pump should I use and what modifications should I do?
Thanks in advance
What oil pump for a 2.5l
- dstar5000
Re: What oil pump for a 2.5l
FULL FLOW AND A 30MM PUMP.
DON
DON
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
pnikas
wreck
apparently EMW now offer a sleeved type 1 pump to suit type 4 cases . It might be worth contacting Jorge at EMW
cal 67
What your operating range will be and the type of driving you'll do should determine oil pump choice. If I was building even a 3.0 liter with a stock operating range and normal driving, I'd still use the stock pump. The size of the oil passages do not increase.
- dstar5000
HE WILL BE RUNNING 20 FT OF 1/2 INCH OIL LINE.... I STAND BY MY ORIGINAL STATEMENT....
DON
DON
