1776 Microsquirt Street Turbo Build
- Schweg
Re: 1776 Microsquirt Street Turbo Build
Looking good!
It’ll boost just fine it’s no longer then mine!
- woodsbuggy1
I have been making some progress, finished up EFI wiring and started on fuel system. I received a few packages in the mail and fuel level sensor is installed and working on fuel pump install.
Kenric
Kenric
Looking good Kenric!!!!!
- woodsbuggy1
Thanks Art, hoping to get new electrical connector for fuel pump and very expensive fuel line for in tank on Monday.
- buguy
Yeah those fittings are not cheap!
Be aware that black hose will melt. Be sure it's not near the header.
- woodsbuggy1
Fuel pump submersible hose is installed, hope I don't have to buy more of that, cost $20 a foot with company discount. Hopefully make more progress this weekend.
Kenric
Kenric
Damn,, napa purdy proud of that hose :shock:like how you told 'Dickhead' how we roll over here too
- buguy
Getting close!
- woodsbuggy1
Decided that 2" between turbine housing and intake was too close, so made a heat shield and almost done with exhaust.
Madmike, thinks have gotten pretty silly on the Dramba. Think I will just leave that trailerpark alone .
Kenric
Kenric
- buguy
Looks good. I'm interested to hear how that little muffler works. I hate firing my car up at 5:30am for work in my quiet neighborhood.
- woodsbuggy1
I will let you know, originally had a 10" glasspack but no room for it so got a Total Flow muffler, hope it isn't too loud.
Maybe one of them turbo blanket/heat shield?
- Schweg
It’s not that loud I have nothing on mine and it’s down right humane compared to a lot of cars around me.woodsbuggy1 wrote:I will let you know, originally had a 10" glasspack but no room for it so got a Total Flow muffler, hope it isn't too loud.
- woodsbuggy1
I pulled my fuel rails to change fittings for braided hose and found that my injectors are corroded and had very fine crystalized dirt in them.
I guess sitting for 3 years with E85 didn't do them any good, they were used injectors from a V8 guy that had been modified for more flow. I cleaned them up and found flow rating marked on each one, they varied from 36lbs per hour to 52lbs per hour, suprised that motor ran so well for 5 years. It was a good excuse to order some 60lbs per hour Deka injectors. Now planning fuel lines while waiting on new injectors. Every build has it's own challanges, in a buggy you have lots of room but limited mounting areas due to lack of firewall and bodywork, will probably be making a bracket that mounts to transaxle to attach FPR and fuel filter.
Kenric
Kenric
Nice 'Z' case trans
