custom fastback
Gasman666
custom fastback
my 1966 euro VW fastback i built and customized. can i get an idea of the HP of my new built engine. My built engine is 1915 cc that is bore and stroke of 94 mm × 69 mm. It has an Engle 110 Mild race Cam. Dual Webber 42 NDIS carbs. Aluminum Cases, cooling fan, and cam gear, Billet lifters. Chromoly push rods, High lift rockers, and elephant feet adjusters which sets my valve lash at 0.0. With ported and polished 041 Heads and polished dual port intake manifolds. Mahle 94 MM race pistons. The flywheel has been lightened to 11 pounds. It has a deep sump, an oil cooler, and an oil filter giving it an oil capacity of 5 quarts and a Long Karmann gearbox
Gasman666
Re: custom fastback
she has done me well
Gasman666
Re: custom fastback
here is a link to a video i made today and loaded on to youtube.
https://www.youtube.com/watch?v=KIbL4mp4Jqs
- Clatter
Re: custom fastback
Right on.
Nice to see a long-term owner.
What are those time slips saying?
Depending upon headwork and a few other things you might have between 80 and 110 HP or so..
A trip to Bandimere over the scales and through the traps will tell you pretty accurately after doing some math.
Heard they plan to close the place, so run it while you can.
