Hey
Thought I better put up a pic of the new throttle bodies
36mm bore with fully machined taper up to 48mm
Inside mount injectors with stainless steel fuel rails
Integral air temp sensor
1/8th vac port feeding from both sides
Will accept most IDF hardware
New IDF Throttle Bodies
- Paul H
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
- V8Nate
Re: New IDF Throttle Bodies
They look nice what's the cost for a pair and do they come with injectors?
- Paul H
I can supply them with injectors I suggest the Pico style which are compact and have a better spray pattern. They are $495 per pair at the moment
due to favourable exchange rate
- Paul H
I've had questions about fan housing clearance and the answer is there is plenty of clearance with a 30hp fan hosing using
tall straight or offset manifolds but sorry they won't fit with a standard fanhousing
- Kafer_Mike
Look great, Paul. Email sent.
