Making progress...
Re: Making progress...
That is the job of owning a dune buggy... constant attention!
Still looking good and worth updating. Have fun and keep us informed of the trials and tribulations involved. :roll: :lol: :wink:
dustymojave
Post by dustymojave »
Way back when you rebuilt that Suby, there was discussion about your shortening the oil pan for more clearance underneath. I felt then and still do that instead of just making the pan shorter, it should also be wider, like a road racing deep sump pan for an American V8. That way you could at least maintain stock oil pan volume, if not increase it. Just might make a situation like this less likely in the future.
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
dustymojave wrote: ↑Tue Sep 27, 2022 11:28 am Way back when you rebuilt that Suby, there was discussion about your shortening the oil pan for more clearance underneath. I felt then and still do that instead of just making the pan shorter, it should also be wider, like a road racing deep sump pan for an American V8. That way you could at least maintain stock oil pan volume, if not increase it. Just might make a situation like this less likely in the future.
Usually when this is done then the oil pickup tube is setup to rotate 180° to make use of the wider sump. Good for oil movement on corners or when accelerating or stopping plus when in inclined areas too.
Skidmark
Post by Skidmark »
When using the shortened oil pan, you don't reduce the stock oil capacity. You still run the required quantity of oil, and the dipstick marks are modified accordingly. I screwed up here, guys. I just didn't check my oil level for too long. Now, why it had consumed that much is probably another reason to crack that egg open and see what needs refreshing.
mgirdner
Post by mgirdner »
If you're not on Facebook, you might not have heard: Skidmark's new shop burned down and his baja bug, and other projects, were completely destroyed in the fire. So devastating.
Lurking in Covina, CA since 2002
  • '69 Baja
  • '73 Thing
mgirdner wrote: ↑Sat Mar 23, 2024 9:46 am If you're not on Facebook, you might not have heard: Skidmark's new shop burned down and his baja bug, and other projects, were completely destroyed in the fire. So devastating.
My thoughts are with Skidmark and his family, friends and customers.
Damn...
STOICH
Post by STOICH »
OH NO! Oh man I have no words for that. I'm so sorry man.
Skidmark
Post by Skidmark »
https://youtube.com/shorts/w27m4JYTu5k?feature=share
This was the last I saw my baja. The fire happened 2 months shy of 20 years of ownership. Thanks, Stoich, for selling her to me. It was one heck of a ride!
BugUgly
Post by BugUgly »
That's hard to watch.
STOICH
Post by STOICH »
That's hard to unwatch.
Damn that hurts.
Before I had ever seen this car I had a 70 hardtop absolutely smashed by a recycling electro magnet crane in a similar situation and then tossed like that after I had rolled it. Really showed me what my roll cage wasn't and broke my heart. Sorry Skid, that really sucks.
Skidmark
Post by Skidmark »
So we are now 2.5 years after the fire. I have an active law suit against Ryobi and Home Depot. We will see where this goes. Shop 2.0 is up, and better than shop 1.0. I made several improvements, including a/c and heating. Increased the ceiling height to 12', and coated the floor. The truck project was restarted, and life goes on.Image
