2276
Panchitos 40x35
CB 2288 cam (=K8) .549 lift with my rockers
Turbo will be a RAD X25-550.
Looking to make 300 HP at 15 psi, revving to 6.5k , maybe 7k once in a while.
Mark Lawless at CB told me I should use VW650 springs. They're super heavy. I'm wondering what the folk wisdom is on this. 40x35 valves are relatively light. I have titanium retainers. Are VW650's overkill? I suppose pressure in the intake tract is trying to keep the valve open, so you might need a heavier spring. But you also have higher pressures in the chamber, trying to force the valve closed.
What is the consensus on valve springs in a turbo motor?
Thanks y'all.
Does a turbo motor need heavier valve springs?
- Crawdad
- blue thunder
Re: Does a turbo motor need heavier valve springs?
I would definitely use a set of good quality dual valve springs, although 650's seem to be a bit overkill IMHO. I am not familiar with the cam you use, but if it is a 'steep-ramp design', heavier springs are recommended.
Use Numbers 1019
Chim them to your needs and rodney's recomandations.
https://logmech.se/eng/products/engine/ ... cessories/
I have no experience but did some research on beehive spring fitment. The thread is in the type4 section. The downside is the lack of collective experience in VW uses.
- slayer61
I think you know the answer already...
Seems like a pretty good recommendation to me.Mark Lawless at CB told me I should use VW650 springs.
