New Exhaust System for '76 Bay
kangaboy
Post by kangaboy »
Will this:
http://www.europeanmotorworks.com/pvw/2 ... eplacement
Bolt directly to this:
http://www.busdepot.com/071251053ek
Don't care about heater boxes, and I still will have the under cylinder tins. Just want to stop trying to booger up the exhaust system with exhaust putty and I have no desire to put new flanges on all the piping.
wildthings
Re: New Exhaust System for '76 Bay
Post by wildthings »
They should mate fine, or you could find a set of 411/412 heater boxes and strip the covers and use them.
kangaboy
Post by kangaboy »
They should be arriving within the week. I'll post pics when I get it all bolted up.
VIPERGREEN76
Post by VIPERGREEN76 »
kangaboy wrote: Wed Apr 29, 2015 2:15 pm They should be arriving within the week. I'll post pics when I get it all bolted up.
How did the new exhaust system work out?
76 SEDAN
EC type 4 Conversion project
As a long term owner of those, expect ... a bit of work making them fit and seal, at least the first time.
They are a lot better than the 411 pipes which are really small bore.
Those appear to actually be made of steel pipe, very thick wall, just too small for anything much more than stock.
My EMW HX replacement pipes finally cracked after many miles and years, too rust thinned to really weld, I will probably duplicate them in 321 SS probably with brazed slip joints if practical, possibly adding some flex joints, as that's really the bane of using stainless in an exhaust, it wants to stretch a lot and return to its original shape.
Given what they cost, I cannot see the case for making them in mild steel or cheaper grades of SS that are more prone to crack.
The Bursch header (mild steel as they all are, bought used for $40) that I run on it still seems as solid as the day it was made.
