Hi Guys.
Is it worth cutting a 19mm sway bar for a 2 inch narrowed beam in the middle , to extend its length for use with a standard length ball joint beam. Thanks.
19 mm sway bar mod
Bruce.m
Re: 19 mm sway bar mod
Worth it? Depends.
Have you got some metal to extend it with? The welder / tools etc. happy with the risk that the weld could fail due to flex at some point.
New sway bar would be around 100, so not much savings?
GARRICK.CLARK1
Yes. Doing the job isn't a problem. I can't sell this bar, as it is , no one seams to want it. which makes it worthless.
I'll give it a go. Not what I'd usually do , but hopefully I can make something of it for little money .
GARRICK.CLARK1
I've a feeling a 3/4 front bar will be too stiff on a light weight fibreglass Vw kit car . It will crash over bumps and the front will let go when cornering on uneven road surfaces.
Bruce.m
For a kit, id go stock.
What do you have out back? Swing or IRS?
(If SA find a Z-bar, take the slack out of it and run limit straps a FJCamper suggests, I'd add using modern foam bump stops)
You may find things line up better than you imagine, and you can reduce the stiffness with an adjustable/movable linkage.
You don't have to use the stock sway bar mounts.
Junkyards have swaybars available in pretty much any size you can imagine, and the widths are closer to the same than you would think, as cars track widths are all pretty much in the same range..
I have personally been eyeing Coleman Racings catalog for the nice, cheap adjustable circle track sway bars for the back of my Cabriolet...
Available in many sizes and lengths.
