Clutch question
Munga
Clutch question
Post by Munga »
I’ve a bay window station wagon I’m building an engine for (type4) and quite a spirited engine I’m hoping it will be .
Now the the van has a 1000kg payload capacity and I’d say that at times I might just push it .
Having said that I am after a heavy duty clutch kit that I will never have to ever worry about!
We do have options: 200 mm conversion with a stage 2-3or even 4 clutch kit OR do we stick with the 215 or 228 mm standard kits?
'77 Westy
Re: Clutch question
Post by '77 Westy »
I’ve had a standard Sachs 228mm clutch in my 2316cc Westy for several years without any problem and it is often fully loaded. I definitely wouldn’t change it for a smaller clutch. What is your ‘spirited engine’ spec?
Munga
Re: Clutch question
Post by Munga »
'77 Westy wrote: ↑Wed Dec 03, 2025 12:52 am I’ve had a standard Sachs 228mm clutch in my 2316cc Westy for several years without any problem and it is often fully loaded. I definitely wouldn’t change it for a smaller clutch. What is your ‘spirited engine’ spec?
1911 with a 10:1 or more compression ratio
'77 Westy
Re: Clutch question
Post by '77 Westy »
A 228mm clutch will be fine with a relatively small capacity engine.
