leaking 48IDF carb.
underbugman777
leaking 48IDF carb.
Post by underbugman777 »
Hey gang! I have a problem with a 48IDF Weber. It is leaking gas into the left runner out of the float bowl. It is not the float being to hight, I believe that it is leaking from one of the progression holes the hole is located on the left side above the butterfly. Does anyone have any idea how I can fix this problem?
[email protected]
vwracerdude
Re: leaking 48IDF carb.
Post by vwracerdude »
a few years later..... any news on this ???
Got a similar issue my self, over fuelling from the float bowl leaking stupidly into both chokes. . . looking at altering float height and replacing the top carb gasket. . ( which does look old to be honest ) .
Any more ideaswould be cool. Cheers :)
