Does anyone run a dry sump oil pump on their T4? where did you get the kit? and hwo deos it perform?
ahnendorp in germany have informed me that they nolonger produce their dry sump pumps, who else might be able to help?
T4 dry sump oil pumps
- Tom Notch
A T1 stock type oil pump will work on a T4, so maybe a T1 scavenge pump can be made to work. Check my site for the T1-T4 oil pump mod. Site listed in my profile.
Tom Notch
Tom Notch
[email protected]
Schadek builds a 2 stage dry sump. Oliver Knuf has them in stock I believe. Oliver was telling me a few weeks ago that he may switch to a dry sump setup. Scat, Schadek, Autocraft, Pauter, and a few others build multi stage pumps. OH yeah, Claudes Buggies has them now as well, but who knows about their?
Steve Arndt
Steve Arndt
yspect8
I have a 2 stage pump. It is in sections like this -- case piece, 3/16" plate, 1.25" blue piece for oil out, 3/16" plate, end piece with in and out.
??? Between each piece is a .006" gasket. Does anyone know the make of this pump? And where to get these 4 thin gaskets? [A normal case gasket is thicker.] I tried Autocraft, FAT, SCAT already.
GDRBO
Have you tryed a normal cover gasket?
