sealing up oil pump?
wbx
Post by wbx »
What do you guys do to effectively seal a type 1 oil pump? Aside from using new sealing nuts, do you coat those thin paper gaskets with anything?
Thanks,
-Damon
milo
Post by milo »
I use a light coating of copper rtv.. I just put some on my fingers and rub it around the gasket... Havent had a problem yet.. If you don't use anything more often than not they leak..
Nathan
wbx
Post by wbx »
Thanks for the quick reply, Milo.
Now, not to sound totally inane and belaboring minutia, do you just thinly coat the gasket between the pump and case, or both pump/case and pump/cover?
Guest
Post by Guest »
should be two gaskets, one between the pump and case and one between the pump and cover.. I coat both..
Nathan
