Mallory Unilite Question
Podunkjr
Looking at the Mallory Unilite, there is one with and one without vacuum advance. Which is better in your opinion? I feel with vacuum adv. is better and that's what I've read. Do your dyno results show the same? Which do you use? Thanks.
- samcat
This has been discussed many a time.
Jake prefers the unit WITHOUT vaccum, and says he hasnt seen a difference with/without the vac advance.
I run the vac advance mallory unilite optical on my 2L T4 and definatly CAN feel a difference with the vac advance connected. Makes it nicer to drive when pulling away, and gained my about 2mpg on my normal runs (short local hops)
Personally I would get it WITH vac advance, and if you decide not to use it simply disconnect the hose! gives you the choice in the future rather than having to buy a whole new dizzy!
Cya,
Sam C
Cya,
Sam C
- samcat
Oh, its also easier to change springs on the NON vac advance unit.
Although personally I have changed spring sets twice and it only took me 10mins start to finish second time around (because I knew what I was doing... not learning like the 1st time which took more like 30 mins)
Remember though, once the engines all together and working nicely then you wont be interested in swapping springs.
Two grey springs is what most people reccomend in the T4.
Cya,
Sam C
Cya,
Sam C
JohnConnolly
Re: Mallory Unilite Question
there will be no difference on a dyno at full throttle, since a vac advance stops working at 1/2 throttle. But from off idle to 1/2 throttle, the additional timing of the vac advance gives better throttle response, cooler running, and more MPG.
How many NEW cars out there have no provision for a timing change WRT load?
Check them at 15hp and 3500 RPM to see the difference.
John
Aircooled.Net Inc.
John
Aircooled.Net Inc.
- Mr. Electric Wizard
JohnConnolly
Dive!Dive!
JohnConnolly
- The_Dude
- factman
i can only compare my vacuum mallory dizzy to a 009 which is what i had before. the difference is amazing and im only getting half the advance since my vents are too big on my bug. climbing hills requires no more throttle than cruising since the load kicks the vacuum advance it. this is on a 1776 with 44 IDF's. i will be putting 40's on with 32 vents and im sure that will make it even better.
SAM
SAM
