You want to do a search on here.
The one thing that has been said about the G50 other that it being about twice the price of a 901/915 is it's a fair bit longer making it difficult to mount in a beetle,not sure about a 356
Check ot this site http://www.ricola.co.uk/
Rich's site doesn't have much on the mounting points / frame for the engine and Junkyard Oval has started to worry me re fitting location. Do you know of any good sites for these?
I have looked at some on earlier threads but they seem to stop before a conclusion is reached!
Twice the price! I've seen a couple of 915s for around £900 so think I will probably stick with known / cheaper technology!
<250ishHP/250 Ft/lbs of torque, a 901 should be fine. Except for first.
A 6061 T6 center plate can be built into it, supposedly good for >>350 HP, as long as you upgrade the CVs of course.
A 915 might be cheaper at that point, save for the clutch bits... They cost major bucks from all I have heard. Should be good to 450 HP.
In a light car, either tranny would take a bit more.
(How fast is YOUR wallet?)
Mr. Ghia used to have some shots of the crossbar front mount and shift adapter he made...
The main issue when using a turbo subaru lump is the depth of the sump. When I fitted the 915 I raised it to get around this problem. Other people have solid mounted the trans which is easy but fro a daily driver prbably not that sensible. The only real reason I recommended the G50 is that if you keep an eye out they do turn up fairly cheaply every now and then and the shift is apparentyl much better. The real downer with the 901/915 is that they do not respond well to fast shifting and if you have the power that's exactly what you want to do!
Tis true... It's partially the clutch design, but hard speed shifting isn't good.
Develop freinds in the auto wrecking biz...
Hey Magic
Check Reub's car. Also I got ideas from Michael Ghia's site. The g50 would be the best, but they are expensive. If the weather ever gets above freezing I will start work on mine again. Then I can pull the body off and get some good photo's.
Check my site http//:photo.starblvd.net/junkyardoval
Not yet. It has been a little too cold to work on it. Will be ordering the 9" clutch and pressureplate from KEP next week. The radiator is in and finished. I have the tubing for the water lines and my wiring buddy is working on the harness. Also working on a couple polished alum. rings so I can mount the Porsche tach and speedo in the dash. Lots of small things to do while the weather is cold. Plan to pull the body and sandblast it in March and put it back on for the last time. I hope.
With a 091 tranny solid mounted, speaking to the passenger is impossible at 55 MPH, and a stereo is useless at any speed.
(OK, perhaps not "impossible, but it's LOUD. The 091 is probably louder than a 901, but it's a data point)
It's my sons car, had to put the T1 trans back in on original mounts for his wife...
We built our own... for the 091, VERY solid, ties into the homeade kafer brace solidly... But that's not what you are doing.
(absolutely no wheel shake, launches beautifully)
He got the wife a "Rabbit" (Golf) convertible awhile back, and he has decided the fast paint job he did wasn't such a great idea... The 091 is going back in as before. He drove it like that for many hard/fast miles (home inspector) before he got the wife the `vert.
He could still hear last I checked, but his stereo could drown out almost anything... but not that trans.
I'm not sure how a 901 mounts in a 911, so I would defer to Mike Ghia.
