Found some wheel hop
Plastermaster
Post by Plastermaster »
David, while you are installing the Kafer 5 go ahead and weld the frame horns if you have not. Ask Jake.
Bert
_________________
_________________
David Gravereaux
welding seams is standard with any performance application.
_________________
Jake Raby
What seams are you guys refering to?
Thanks
Ron
EASY RIDER
Post by EASY RIDER »
Sorry Ron....you will have to get your engine first. :lol: J/K
Where the frame horns are spot welded together you grid down the inside and outside just a very small amount to clean up the mateing surface and that is where you weld. The two halves, top and bottom, are spot welded on the flat spot and Jake suggests that the ends are welded up for more strength. Starting at the end: weld 4 inches and then skip 4 inches and continue this all the way to the tortion bars. On the inside and outsides of the frame horns. Did I explain that enough? :?
DAVID, what is the price for that brace? Can you find out so that I might be able to stop the one from Top Line. That brace is SOOOOOOOO cool. I don't know what good it really does but it looks tough.
Bert
Plastermaster
Thanks Bert. That was very clear, But if I have to get the engine first, is it OK if I weld the seems before I put the engine in? :D
Ron
davygrvy
Post by davygrvy »
EASY RIDER wrote:DAVID, what is the price for that brace? Can you find out so that I might be able to stop the one from Top Line. That brace is SOOOOOOOO cool. I don't know what good it really does but it looks tough.
Bert
No clue on the price or availability of that brace. I'd phone or email 'power tuning parts' to ask as their website is blank.
No room for a spare! Thought I'd mention it. Not like I can put a full size spare in mine given the stock trunk as is, but with that X brace, no spare at all is my guess...
davygrvy
Post by davygrvy »
Plastermaster wrote:Thanks Bert. That was very clear, But if I have to get the engine first, is it OK if I weld the seems before I put the engine in? :D
Ron
I would actually recommend that.. :P
EASY RIDER
VERY funny Ron! :lol:
What do you mean no room for a spare? Don't you have a super? You can still keep the spare, you would just have to be able to undo the front section of the brace to get the spare out.
Bert
davygrvy
Post by davygrvy »
Got a pic of a super with an X brace? I visualize it going thru the middle of the spare :?
EASY RIDER
There was a picture or two on www.germanlook.com but I can't find it.
Dave, the brace goes to the top of the spare just under the lip where the hood closes. You can still keep the spare because the brace does not go down into the well.
Buy it! I think you need it! You can't live without it!
Someone stick a picture of one installed up so he can see it in a car, please.
Bert
73notch
Post by 73notch »
anyone know anything about the ISP west setup? looks good and the price is decent.
Plastermaster
73notch wrote:anyone know anything about the ISP west setup? looks good and the price is decent.
Bump
EASY RIDER
No,..............................I sent ya some pix Dave. On your email.
Bert
Plastermaster
If you look at the pics on Ebay of the ISP bar, it looks like the attatchment to the top of the shock tower will require a chunk of metal to be removed from the body around the access hole to the shock bolt. The prescott bar just fits into the hole.
Ron
The Tractor Supply Braces are still only ~$100, not lightweight, totally preloadable... And suitable for wheelie bar mounts if you set it up right.
I think Tuna put my pics up on his site...
Plastermaster
Piledriver wrote:The Tractor Supply Braces are still only ~$100, not lightweight, totally preloadable... And suitable for wheelie bar mounts if you set it up right.
I couldn't find them. The tractor parts are similar to turnbuckles and are used as part of what is called a 3 point hitch. Alone they would only make up a "2 bar st up" lacking the horizontal bar, right? How did you do yours?
Thanks
Ron
I don't see the pics on his site, fire me your e-mail and I'll send pics.
(button below works)
And it DOES have a crossbar... Also used anoother bar up front for a strut brace (71 super)
Locked
