A-1 header done and ready for testing by Jake
- DaveB
- tuna
From the photos, it might. I can't say for sure, but it seems like the Type 1 headers had problems with the bumpers on an early Bus, so the collector placement and the muffler are going to be areas to watch out.DaveB wrote:Hey Tuna
Any opinion if this will fit the back of a Splitbus w/DTM T4?
I have a "custom" rear apron so mods are not a problem. Saw an A1 system at the local shop for a T1, nice work.
Dave
Ideally, you should take the Bus to Tiger and have him make a header for your Bus. Barring that, I don't know. You might drop Tiger an email or give him a call and talk with him.
Tuna
P.S. You might wait until Jake does the group buy, see if he'll sell you one on a "only if it fits" basis. That way we'd know and you wouldn't be stuck with the header if it didn't work out. I'm not saying that Jake would do it for sure, but it's worth asking.
Tigers new header system
Well boys I am here form up North. I have been reading the forms for years and I have purchased a set of 103 Nickies and I am broke but ready. I read about Tigers A-1 Header and if I am able to enter into the group purchase?
I have lots of questions and for sure you guys are the best soooooooo
here's one. Can I use stainless steel valves if using 103 nickes ceramic lifters,163/86b Webcam, and a 78 strokercrank.
Thanks guys.......
[/u][/i][/b]
Thanks guys.......
A1 header
The engine setup is again103x78 crank,163/86b cam with the RPM @ 6500 approx. according to Charles which asked me to contact you guys who are the pro. HP is ?????
Would a 1 5/8 header be enough or would I kneed 1 3/4"
The Transmission is a T1 modified 4spd with welded gears, Super Diff,Aluminun side cover, steel forks and gussted.3:88/3.30 /2.07/1.39/1.04
Thanks........
Thanks........
