Whiteline front adjustable sway bar install for std bug
- Bill K.
After finding out I had installed my sway bar wrong through a post in this forum, I fixed it (I think) and wrote up some instructions. Edits/corrections welcome.
Originally, I had the shock bracket up side down which reduces ground clearance. Also, the bar rotated on the beam during a hard corner causing the tire to rub on the fender lip. I didn't have the U-bolts tight enough. Now the U-bolts are welded to the beam so they can't rotate. Fixing it took some work, but it's better this way. It handles nice now, even before final alignment, etc.
Addicted to G,
Bill
Addicted to G,
Bill
Well the blue paint is giving way to rust quickly. Must be realy crapy paint it's only been installed for 6 months or so.
Did you guys have any problems witht he shock bolts working loose?
Theo
Theo
Aurumen wrote:I'm just upset that you guys that bought the bars more recently than I did have the grey color instead of the gross blue bar that I have...hehe. Good work and good tips. I too had to learn the hard way on some of that stuff.
Nick
- Bill K.
I did not cut a window but I ground it to fit. I will double check to make sure it is not rubbing my Koni shocks.
The window looks to give better clearance.
Theo
Theo
Bill K. wrote: Theo -- did you make window cutouts in the shock mount brackets. If not, maybe yours are rubbing on the shock and working the nut loose as the shock pivots.
My bar rubbed the shock towers too. I didn't like the idea of cutting/grinding the towers as that was my first idea. Instead, I fabbed up some more pillow blocks (1/4" thick) to stack behind the ones that came in the kit. It did two things. 1: It gets the bar off the shock towers, & 2: It moves the whole bar forward, so while I'm in the 21mm adjustment (where I run it), the link bolts are vertical above the center hole in the lower mount keeping it from being an eccentric mount and possibly twisting.
Ben Franklin
Ben Franklin
just a tip if you don't like the idea of welding u bolts to the lower beam, you can buy some exhaust flanges like these
http://store.summitracing.com/partdetai ... toview=sku
then bolt the u bolts through them into the brackets, mine have held for some time. i forget the size though
rip
rip
