Hi!
I have 40 horse engine whit big bore,ported single port heads,small cam,header and zenith.I have also isolated tube intake and plenum style intake.Now I need help to choose.What is bedder isolated or plenum?It´s daily driver,and I want it´s easy to drive.
Thanks
plenum or isolated tube
Loïc
Re: plenum or isolated tube
Isolated manifold is better for a 40hp daily driver engine.Stinde wrote:Hi!
Thanks
- Marc
Loïc
I never tried with the old Zenith 32 NDIX but i used a Weber 36 IDF with some home made manifolds and tried the 40 hp engine with a engle Vz14 cam => the result were better without the plenum chamber in the lower rev range so i don't think it's a good idea for a daily driver engine.Anonymous wrote:have you tryed plenum whit zenith
Guest
