balljoint coilover setup?
volkdent
1960 "Bad Dub" http://youtu.be/VEUPxTw11hk
Drag http://youtu.be/NNcPQDiNPQE
Dyno http://youtu.be/51_JRESS0Tg
1957 "Ragster" http://germanlook.net/forums/showthread.php?t=11514
volkdent
FINALLY! Got a quote back from the laser cutter. Apparently I'll have some laser cut pieces in my hands in a couple of weeks, so fabrication can begin!
Jason
Jason
volkdent
Well, I don't know about better, though it probably will be, but DEFINATELY less expensive and virtually no modification to the body and slight modification to the pan. The one thing that has to be modified a lot is the gas tank, so you can either ditch it all together and go with a racing cell or something, or one of those spun aluminum jobbies. Currently I've just bashed a big dent in it to clear the UV joints of the steering rack, but in the long haul I will be cutting out a section and then welding in the area to clear, losing a little volume of the gas tank in the process.
Jason
Jason
volkdent
The laser cut parts are currenty being made. Apparently they'll be done next Monday. That would be great, as it's my day off, and I can hand deliver them over to Walt to get going on the fabrication. Being as this thing could be done soon, I'm having a hard time keeping my attention on the rear end!
Jason
Jason
volkdent
If you want to see this thing come to life, Bob just emailed me a 3d file that can be used with the FREE ModelPress reader found at:
http://www.modelpress.com/download.htm
So if you want to check it out in realtime, drop me an email and I'll send you the file for viewing.
It makes me all giggly just to look at this thing!
Jason
Jason
volkdent
Picked up the laser cut and press brake parts today. $660 and 24.5 lbs.
Monday the parts will be going to Walt!
Jason
Jason
volkdent
Done is pretty subjective. It looks like it's never seen the road, and apparently this was done some time ago, before the business was sold, or so the story goes. It was done before I ever started my project, but I didn't see it till after the design of mine was done. The main difference in these suspensions is the steering rack, it controls all the dimensions.Rhino wrote:Have you guys looked at what EYEBALL-ENGINEERING.NET is doing with an A-arm front susension???!!!
Go to "current Projects"... they have a working A-arm front susension all done!!!
I might try another one later using a Super steering rack, as it might fit better, but we'll see.
Jason
volkdent
All the parts are now in Walt's hands. He'll be taking digital pics of the progress, so as he sends them to me, I'll post them.
Jason
Jason
volkdent
it begins.....
This is what Walt got done in one day. I can't believe it. I was thinking it was going to take awhile, as everything else in the project has.
http://www.geocities.com/volkdent/Front ... rtial.html
It may say the page is temporarily unavailable. Its free, so if too many people look, it shuts itself off for awhile. Thanks YaHOO! Ba$tards!
Just keep checking in on in, it will come back.
Jason
Jason
volkdent
The Light is VERY Bright!!!!
This is basically done now, with the exception of final welding and the addition of new shock towers that allow for more travel. Whatcha think?
http://www.geocities.com/volkdent/SuspensionOn.html
