2.2 chrysler turbo ,anybody know what it is?
oldmech
Post by oldmech »
will this turbo spin up if installed on
my new sandrail with 1600 subaru?
may the wind not blow
away all your tracks!!
newestone
Post by newestone »
I DON'T KNOW WHAT THE CHARACTERISTICS ARE OF THE SUBARU ENGINE ARE BUT I DO KNOW THAT CHRYSLER 2.2'S WERE EQUIPED WITH GARRET T03'S
THE 2.5'S HAD MITSUBISHI T04'S. IF YOU CAN FIND A COMPRESSOR MAP THAT WILL TELL YOU IF IT'S RIGHT FOR YOUR ENGINE.
GDRBO
Post by GDRBO »
Christmas Valley as in near Wagontire? Or the lost forrest?
oldmech
Post by oldmech »
thanks newstone,where would i find a comp.
map?
yes GDRBO christmas valley,or. 20 mi. from
C.V, dunes
Miker76
Post by Miker76 »
The t03 used on chrysler 2.2 engines had lots of lag, lag of the 1980's that turbos got a bad rep from. This is a very popular turbo and comes in many different trim and a/r ratios, but seeing as how much lag it had on a 2.2, your 1600 would have a hard time spooling it up. The chrysler 2.5s' mitsu to4 was implemented to rid these engines of lag, so it is smaller, therefore better for your engine size. The first generation talon/laser/eclipse use this turbo also. If I were you, I would use a turbo from a second generation talon/eclipse. It is a garrett t25, a little undersized for the 2.0l mitsu engine but nicely matched to your engine. Hope this help!
Mike
oldmech
Post by oldmech »
thanks miker,I wish I had a 2nd gen car in
my back 40,anybody want to trade?
Miker76
Post by Miker76 »
If you are ok with ebay, you will find a few for sale there, as almsot all those guys replace them with a larger turbo. Check it out.
Mike
newestone
Post by newestone »
if you do use the the turbo from a mitsu. and longevity is a factor make sure it is a garret turbo they are rebuildable the mitsu. turbos are not
Matt Keene
Post by Matt Keene »
Try this site for Garrett compressor maps: http://www.turbofast.com
The last time I looked they had loads to download/view...
newestone
Post by newestone »
are you sure that is the right adress? the link is not working
oldmech
Post by oldmech »
I did a search , add .au to add., lots of info I didn't understand + some good links.
Matt Keene
Sorry, this should work... http://www.turbofast.com.au/welcome.html
